4 members (MickeyP, Ole49GMC, Tronman, Peggy M), 83 guests, and 1 robot.
Topics128,043
Posts1,055,610
#72846 02/06/2007 1:24 AM
Hello Wise Ones,
Its been a few years since I have been able to start back on my 59 Panel.
I have ordered the following parts from CCP in southern California, powersteering conversion kit, Stock brake pedal power brake booster/master cylinder and 5 lug disc kit.
And now I see there is a new rack& pinion powersteering kit from no limit engineering.
Has anyone installed the powersteering kit from CCP? I am really interested in how this setup works and if I should use the CCP kit or get the rack & pinion set up instead. Also wondering how the disc power brake set up works? good or bad please someone tell me how your truck stops with the conversion verses the stock drum setup and if there are any good installation tips or does the stuff bolt right up?
My truck will have a 454 th400 combo with a 12 bolt rear from a chevelle.
Thanks Bill
go to www.flamingriver.com and look at their power steering column to hook up to manual. works if you want to replace your steering column. it is new this year, look in new products. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I put the straight axle power steering assist in my 1951 1/2T PU ...it worked great and was easy to install. The system is similar to the ram & piston style of power assist steering used in the early Corvettes. It's an expensive unit but overall it takes less labor & effort to install..and contrary to the previous comment I encountered no additional vibration or feedback into the wheel from this unit.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
SteveG isn't talking about a axle-mounted rack, I don't think. He is talking about the kit that uses a valve body where the pitman arm meets the drag link and a piston from the axle to the tie rod.
Paint & Body Shop moderator
If the rack is mounted on the axle and moves up and down with the axle how dose the steering shaft from the column hook to it?
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Steveg check out my webshots page and you can see how I have done mine. Grigg here on the bolt has done the same. IMO it is superior to the kit from CPP. I have used a Scout II steering box and ran the drag link to the right side of the truck. Longer drag link give you less bump steer. Also the spindle and pitman arm move in the same ark this way.
user
