| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72846 02/06/2007 1:24 AM | Joined: Mar 2003 Posts: 49 Member | | Member Joined: Mar 2003 Posts: 49 | Hello Wise Ones, Its been a few years since I have been able to start back on my 59 Panel. I have ordered the following parts from CCP in southern California, powersteering conversion kit, Stock brake pedal power brake booster/master cylinder and 5 lug disc kit. And now I see there is a new rack& pinion powersteering kit from no limit engineering. Has anyone installed the powersteering kit from CCP? I am really interested in how this setup works and if I should use the CCP kit or get the rack & pinion set up instead. Also wondering how the disc power brake set up works? good or bad please someone tell me how your truck stops with the conversion verses the stock drum setup and if there are any good installation tips or does the stuff bolt right up? My truck will have a 454 th400 combo with a 12 bolt rear from a chevelle. Thanks Bill | | |
#72847 02/06/2007 3:03 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | go to www.flamingriver.com and look at their power steering column to hook up to manual. works if you want to replace your steering column. it is new this year, look in new products. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#72848 02/06/2007 3:48 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I put the straight axle power steering assist in my 1951 1/2T PU ...it worked great and was easy to install. The system is similar to the ram & piston style of power assist steering used in the early Corvettes. It's an expensive unit but overall it takes less labor & effort to install..and contrary to the previous comment I encountered no additional vibration or feedback into the wheel from this unit. | | |
#72849 02/07/2007 11:02 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | SteveG isn't talking about a axle-mounted rack, I don't think. He is talking about the kit that uses a valve body where the pitman arm meets the drag link and a piston from the axle to the tie rod.
#72850 02/08/2007 2:08 AM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | If the rack is mounted on the axle and moves up and down with the axle how dose the steering shaft from the column hook to it? | | |
#72851 02/08/2007 2:19 AM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Steveg check out my webshots page and you can see how I have done mine. Grigg here on the bolt has done the same. IMO it is superior to the kit from CPP. I have used a Scout II steering box and ran the drag link to the right side of the truck. Longer drag link give you less bump steer. Also the spindle and pitman arm move in the same ark this way. | | |
