Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Dakota Bob, J Lucas, 46 Texaco, tclederman), 110 guests, and 3 robots.
Topics128,282
Posts1,058,490
Members48,490
#728016 03/08/2011 9:38 PM
I'm looking for a custome rear end for my 46 pickup any reccommendations?
It depends on how much power you are going to put to it and your wheel/tire combo. I am using a 2000 4x4 Blazer rear end. It is the exact same width as the stock rear end out of my '39 (I am using stock size wheels/tires), it has disc brakes and comes in a 3.42 or 3.73 gear ratio. They will not take a built V8, but work good with a mild 6. I cut off the stock spring perches and welded on the correct size in the correct location for my springs. I had Moser Engineering weld and redrill the brake rotors and axles for the 6-lug pattern. If you will be using non-stock wheels the rear end matches up well with the 5-lug disc brake conversions, as it has the standard 5x4-3/4" lug pattern used on most mid sized GM cars.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
