| | | Forums66 Topics128,210 Posts1,057,459 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 39 New Guy | | New Guy Joined: Feb 2011 Posts: 39 | have decided to upgrade to front disc brakes and have been unable to find a kit for my spindles. looks like the easiest solution will be to switch to a half ton front axle and spindles and use cpps half ton six lug kit. here comes the question. i am running lt235/85 size tires on my 16 inch 8 lug rims. what 6 lug rim will allow me to keep a fairly stock look and my tires? where can i find em cheap? thanks aubrey are | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | You may want to rethink changing to the 1/2 ton disc brake conversion. For the most part 3/4 ton trucks have great brakes, the weakness is the master cylinder. I have done several power brake upgrades on these trucks. A booster and a dual master cylinder will do wonders, is more cost effective, and you won't have to run different wheels. Fred
