10 members (Tronman, Steelonsteel, Peggy M, Rusty Heaps, J Lucas, Wally / Montana, Scott, klhansen, 2 invisible), 65 guests, and 1 robot.
Topics128,206
Posts1,057,433
Members48,471
have decided to upgrade to front disc brakes and have been unable to find a kit for my spindles. looks like the easiest solution will be to switch to a half ton front axle and spindles and use cpps half ton six lug kit.
here comes the question.
i am running lt235/85 size tires on my 16 inch 8 lug rims. what 6 lug rim will allow me to keep a fairly stock look and my tires?
where can i find em cheap?
thanks
aubrey
are
You may want to rethink changing to the 1/2 ton disc brake conversion. For the most part 3/4 ton trucks have great brakes, the weakness is the master cylinder. I have done several power brake upgrades on these trucks. A booster and a dual master cylinder will do wonders, is more cost effective, and you won't have to run different wheels.
Fred
