1 members (1 invisible),
88
Mod | | | Forums66 Topics128,192 Posts1,057,226 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | Just got a 1950 6100 chevy dump. has the 2 speed rear end and vacum brakes-Brakes currently aren't working can hear air leaking when running. does anyone know a resource for manuals and info for these trucks ?
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | don't know yet, just got it running, motor is still sputtering just looking for a manual to get aquainted with the system never work with air brakes before.
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Vacuum brakes aren't air brakes, which do you have?
I'd guess vacuum boosted with a hydrovac, if you plug what sounds like a vacuum leak it may run smoother while you figure out the rest of it.
Grigg | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If you are hearing what sounds like an air leak, you probably have a bad vacuum leak. And your engine will be way too lean and never will run right. I would remove the vacuum line from the center of the manifold and plug it until you get the engine right. I would then search for the source of the vacuum leak. | | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | pretty sure I've got the wagner air brakes - big belt driven air compressor on the front drivers side of the motor, with the wagner 160psi guage in the cab and a big resevoir underneath the drivers side of the dump box.
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | Is the gauge building any air pressure at all? There's a "governor" mounted somewhere on the air compressor that routes air pressure to the valves inside the compressor and holds them open when the preset pressure is reached. Sometimes they stick in the "release" position and prevent pressure from building up. The governor is a round housing about 1 1/2" in diameter and about 4" long, held onto the compressor by two bolts. Jerry
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | WOW !, Sounds like you have a Wagner Air Brake Conversion, which was an accessory add on from Chevrolet Dealerships. That's a "Rare" setup, you have there. I've only seen one, in all my years of messing with these Advance/New Design '47-'54 GM trucks. I'd like to see some photos of your truck, & Air brake setup. Air brakes weren't available on Chevrolet Trucks from the Factory until around 1956. | | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | let me look how to post Pics here. and I will!
I see in your post that you collect the COE's that was what got me started on this, just missed out on a SWB COE dumptruck another guy showed up at the same time and opened with"i'll give you more than your asking for it" so I wasn't going to get into a bidding war at the beginning end of a project. a buddy of mine stumbled on this truck and I couldn't pass on.
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Yeah flem, click into my links, & you'll see my webshots albums. webshots would be a good photo sharing site for you to ad links to photos. Photobucket, & flickr also. Been collecting COE's, & holmes Wreckers, for over 25 yrs. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Now that's a NEAT TRUCK. You have an accessory Vacuum booster pump mounted to the driver side firewall also. And accessory electic air horns. That's a "Great Score" there. These goodies, make for a "Rare" truck. Thanks for the photos. | | |
