| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 22 New Guy | | New Guy Joined: Aug 2004 Posts: 22 | will late model colorado 16 in. wheels fit my 50 chevy 3100 ? When swapping to a chevy v/8 will the colorado rear end fit ? thanks ,Bob | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Your width, backing plate to backing plate is 62" +-. Measure what you want to use and you will see if it will work. You can fudge a bit but look before you leap.
~Jim
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The wheels will not work, backspacing is too deep and will cause rubbing issues. I have measured the rear axle on a Colorado, though, and beleive the rearend might work. I don't recall the exact dimension (should have wrote it down), but I beleive it is right around the 62" plate to plate.
Bill Burmeister | | |
