| | | Forums66 Topics128,050 Posts1,055,751 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members: I am in the process of cleaning up my motor compartment and all that is within it. Have already stripped and repainted the motor, new fuel pump, wiring, alternator...etc. I took off my exhaust due rust and lots of holes in the pipe. I then took off my manifold and cleaned and painted. I want to put on a dual exhaust system...but I want to keep the original intake manifold. The truck has a Rochester single barrel..but after reading alot of posts...I don't want any leaking or problems after spending months cleaning the motor area. I don't know squat about carbs... I do know that I want a daily driver no speed demon... I don't want Dual Carbs....
I live in the Santa Cruz Mtns. So thats my terrain. I want it to work good with the dual exhaust also. I will be using the stock choke cable and would like to have the Throttle cable hook up...since it's on my dash...if I can't I'll just have a dummy knob.
Any and all opinions welcome. ps..I don't want to spend a fortune either.
Thanks Guys | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I'm going thru some carb issues to, I think the best thing to do is go with the Langdon carb settup for 155.00 You get the carb,the adaptor plate,the linkage,and the air cleaner ,and every one says they run great.And You'll be done and have a good running engine and down the road the carb is rebuildable so the settup will last .
Pete | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | What kind of carb is in the Langdon setup ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Langdon's Stovebolt Engine Company sells a few different carbs for dual-carb set-ups.
Holley-Weber Carter-Weber
Maybe someone will comment about using only one of these on a 235? (you say you want a single carb set-up)
Does Langdon's sell a single carb set-up? His website has not been working recently.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | And then, there's the option of rebuilding the "rot-pot" you've got now. The standard knock on these carbs are warpage of the individual castings and wear at the throttle shaft.
If you do some internet searches you'll find easy solutions for these issues. I didn't have either of these problems when I rebuilt my "B" 6 years ago. No leaks, good performance at all engine speeds. I know I'm probably in the minority here but in my opinion the ol' "B" is a good carb for the 235. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I like my Rochester B too. This subject is like a religion. I expect this thread may grow a bit! | | | | | Joined: Nov 2010 Posts: 63 New Guy | | New Guy Joined: Nov 2010 Posts: 63 | Yeah, I'm probably blessed with a "good" Rochester too. Since I've taken possession the motor has ran really well. I just sent mine off to be rebuilt I hope my luck continues with this carb. | | |
