5 members (Steelonsteel, Hotrod Lincoln, 55shaker, ShopRag, 78buckshot), 100 guests, and 1 robot.
Topics128,035
Posts1,055,552
#725511 03/01/2011 5:12 AM
A 1953 Chevy truck, what can I use as a frame swap? I was thinking of that instead of using the original. Any ideas?
Termite53 #725592 03/01/2011 4:16 PM
1 Offline
S10 frames are the most common (kits available online), some late 80s blazer frames have been done before, and mine is on a 64s chevy truck 4x4 frame. Also heard of dodge Dakota being feasible along with some jeeps.
Termite53 #725630 03/01/2011 6:10 PM
Why?
Cletis #725633 03/01/2011 6:15 PM
Ford Explorer frames fit well under some rigs-they are basically flat from front to rear.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
64fleetside #725702 03/01/2011 10:45 PM
What are you wanting to accomplish by doing a frame swap? IFS? 4X4? Some more information on what your plans are would be helpfull in determining what frame best suits your needs.
Personal opnion, the stock frame would be best.
Bill Burmeister
LONGBOX55 #725716 03/02/2011 12:07 AM
I've had this truck for almost 20 years now. Believe it or not I've been buying parts all these years and now maybe going to start to work on it. Although I've had thoughts of selling it all and saving for a 2010 Camaro. I've got about $12,000 in parts lying around. I have all parts to do frame, dropped axle, lower springs,shocks, etc. But I was just thinking it might be easier to but a more modern frame under it? Maybe buy a wrecked truck and use as much of it as I can. I don't know after all thses years trying to decide what to do. I want to keep it simple.
Termite53 #727038 03/05/2011 8:39 PM
Since you want to keep it simple, stay with the stock frame. Period!
With the 3 inch dropped axle and mono springs it should set pretty good. The tires I bought are 285/60/15 for rear and 235/75/15 for front. I'm working at NAPA since retireing from UPS and the guys in machine shop said they can save me alot on the machine work. Also one of the perks for working there is I get parts at cost. They tell me I can build my engine for under $1500. Nothing crazy! Maybe this summer if I can get started on it I will get inspired to keep going. I built a 69 Camaro back when I got out of high school in 1978 and I guess this isn't any worse. My wife wants me to give up but I just can't seem to do it. I've pictured the truck done so many times in my head!Thanks for the help!!! Maybe one of these days I'll post some pictures of this basket case!!!
