1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | After finally getting my 216 running really good, all of a sudden it is over heating. Currently no thermostat, replaced the water pump...no change! Now, it sat since 1972 before my attention. Whats the chance I plugged the radiator with scale or rust or something? | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | You need to flush the radiator if it's been sitting that long.I would take it to the local shop to also have it tested .When the radiator is in the shop you may want to look at the water passages removed hoses and thermostat housing .Use a water hose to flush the engine water passage you want it all clean .Good luck . | | | | | Joined: Oct 2010 Posts: 45 New Guy | | New Guy Joined: Oct 2010 Posts: 45 | "Currently no thermostat" You definitely need a thermostat and be sure to check the opening temp in a pan of water on the stove with a good thermometer before you install it. | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Found the prob...radiator was plugged. Took it out, ran garden hose in it upside down, lots of "stuff" came out. Probably from sitting so long. Re-installed with new coolant. Doesn't run any hotter than about 160 now. | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Ok....here we go again. Overheating! Old radiator was plugged. Bought new one , flushed engine as well as I could. New rad performed flawlessly...until today! Still do not have many miles on truck since getting back on road. Water/antifreeze has mostly a rust color to it. There has got to be a way to flush this old engine WITHOUT running the fluid thru the rad. I have drained and re-filled the antifreeze 4 times now. Still have bad looking coolant. Has anyone ever contrived a way to flow water and flush fluid thru the engine but by/passing the rad, even if pausing to let it cool occasionally. I will probably have to have this new rad professionally cleaned now! I haven't even had enough time to use the Peak flush and clean product
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | After refilling the cooling system, sometimes an air-pocket can get trapped under the thermostat, which will prevent it from opening, even when it's hot (the air doesn't transfer heat nearly as efficiently to the thermostat as water does, so it doesn't "read" hot enough to open.) Does it sound like that's what could now be happening?
Common practice is to drill one or two small holes in the side flange of the thermostat, to allow air to escape to the top of the radiator and out as the water circulates.
Otherwise, sounds like just a lot of flushing is necessary.
-Michael | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would also check your vacuum advance and timing. A bad one can help cause over heating.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Ditto that, plus fuel delivery. I'll never forget my 216 gradually overheating from a lean condition, while it ran worse and worse. My buddy reached over and pulled the choke out a little. The difference was immediate. Cured it right up.
Heck - just check and fix EVERYTHING, and it won't overheat anymore! ;-)
-Michael | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | You probably have heard this already, but if your truck has been sitting so long you can bet the the block needs a good thorough flushing. I have done this on a number of old motors, and finally I learned that if you haven't opened up the rear petcock on the block (down behind the steering shaft)you haven't really flushed it. When I have finally got that drain opened usually it is so gummed up down there that nothing will drain. I've had to go in with a chopped off clotheshanger to loosen the crud that accumulates back there. When it finally starts to drain it will be pure mud. Failure to flush this crap out can lead to overheating and a cracked block. Don't ask how I know this last part.
Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
