| | | Forums66 Topics128,162 Posts1,057,065 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 6 New Guy | | New Guy Joined: Mar 2011 Posts: 6 | Hi Gang! New to stovebolt! I have a 37 1/2 ton PU Great Lil Truck A older gentleman owned & drove to high school & owned truck til he was 68 yrs old & passed away & I bought truck! In 1957 he put a 56 265 V-8 in in & super old school! They Cut the 6 Cyl Bell housing & V-8 Bell housing In 1/2 & welded together so still has 4spd granny low trans & closed driveline! My Question is will a truck 3 speed out of a 40 chevy pu fit in place of 4 speed? I would rather run 3 speed as I don't need granny low! Has anybody that you know of done this & will a 40 fit? Tks Bill | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | 37 1/2 ton would have came with a 3 speed transmission. Does the shift lever have a small rod on the left side that goes to a metal lever that you lift up on to put it in reverse? If it does its a pre 48 big truck 4 speed transmission. I think that 46 was the first Chevrolet light truck to have a 4 speed transmission. | | | | | Joined: Mar 2011 Posts: 6 New Guy | | New Guy Joined: Mar 2011 Posts: 6 | Yes It Does Have A Lever! Would a 3 Speed go back in & a 40 work? It has the clutch linkage hooked to the side of trans! Did 37's have that also? Tks Bill | | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | My '37 has the original toploader 3sp. It has bosses on either side of the transmission as mounting points for (left side) brake master cylinder and (right side) emergency brake. The rear of every Chevy '6' block (216, 235, or 261) is the same from 1937 through 1962, and the flywheel/crank-flange pattern is the same from '41-'62. So theoretically a 3sp from a '40 would fit the '37. Here's a pic of the original configuration on a '37: http://i1098.photobucket.com/albums/g369/J-reb/1937_Chev_Pickup/37_Chev_Trans.jpg
Everything is different now...
| | | | | Joined: Mar 2011 Posts: 6 New Guy | | New Guy Joined: Mar 2011 Posts: 6 | Hi! Thanks For the great pic & info it does Help Bill | | |
