5 members (Jethro in Va, 1955 1 Series, moparguy, 50_TON, ronsway), 342 guests, and 4 robots.
Topics128,159
Posts1,057,029
Members48,460
Just got a 1950 6100 chevy dump.
has the 2 speed rear end and vacum brakes-Brakes currently aren't working can hear air leaking when running.
does anyone know a resource for manuals and info for these trucks ?
50 chevy 2-ton dump
71 C-20 Suburban 402/400
72 C-10 Suburban 350/3-speed
everything you need to know can be found here. http://chevy.oldcarmanualproject.com/shop/1948_51truck/index.htm
air leaking from where?
don't know yet, just got it running, motor is still sputtering just looking for a manual to get aquainted with the system never work with air brakes before.
50 chevy 2-ton dump
Vacuum brakes aren't air brakes, which do you have?
I'd guess vacuum boosted with a hydrovac, if you plug what sounds like a vacuum leak it may run smoother while you figure out the rest of it.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
If you are hearing what sounds like an air leak, you probably have a bad vacuum leak. And your engine will be way too lean and never will run right. I would remove the vacuum line from the center of the manifold and plug it until you get the engine right. I would then search for the source of the vacuum leak.
pretty sure I've got the wagner air brakes - big belt driven air compressor on the front drivers side of the motor, with the wagner 160psi guage in the cab and a big resevoir underneath the drivers side of the dump box.
50 chevy 2-ton dump
Is the gauge building any air pressure at all? There's a "governor" mounted somewhere on the air compressor that routes air pressure to the valves inside the compressor and holds them open when the preset pressure is reached. Sometimes they stick in the "release" position and prevent pressure from building up. The governor is a round housing about 1 1/2" in diameter and about 4" long, held onto the compressor by two bolts.
WOW !, Sounds like you have a Wagner Air Brake Conversion, which was an accessory add on from Chevrolet Dealerships. That's a "Rare" setup, you have there. I've only seen one, in all my years of messing with these Advance/New Design '47-'54 GM trucks. I'd like to see some photos of your truck, & Air brake setup. Air brakes weren't available on Chevrolet Trucks from the Factory until around 1956.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
let me look how to post Pics here. and I will!
I see in your post that you collect the COE's that was what got me started on this, just missed out on a SWB COE dumptruck another guy showed up at the same time and opened with"i'll give you more than your asking for it" so I wasn't going to get into a bidding war at the beginning end of a project.
a buddy of mine stumbled on this truck and I couldn't pass on.
50 chevy 2-ton dump
Yeah flem, click into my links, & you'll see my webshots albums. webshots would be a good photo sharing site for you to ad links to photos. Photobucket, & flickr also. Been collecting COE's, & holmes Wreckers, for over 25 yrs.
Spanky Hardy
1950 GMC 250 1-Ton
see if this works,
pics are from when we picked it up
http://s1198.photobucket.com/albums/aa460/jflem3/
50 chevy 2-ton dump
Now that's a NEAT TRUCK. You have an accessory Vacuum booster pump mounted to the driver side firewall also. And accessory electic air horns. That's a "Great Score" there. These goodies, make for a "Rare" truck. Thanks for the photos.
Spanky Hardy
1950 GMC 250 1-Ton
