1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
I intend on placing a drop in gas tank between the rails in the rear.
what I can't seem to find is a total dimension of.
from the frame rail top to the bottom of the boards in the bed.
I know there is the bed cross sill height and the bed support blocks, to maintain position.
I'm wanting to know how much area above the frame do I have to play with in designing a gas tank mounting set up.
an yeah I know...i shoulda measured before I took off the bed....oh well..live and learn headscratch
Hank Flowers
Cut and Shoot Texas
1952 3/4 Ton 3600
http://flic.kr/p/8RQvKZ
What truck do you have?
Evan
1952 3/4 ton 3600
Hank Flowers
Cut and Shoot Texas
1952 3/4 Ton 3600
It depends on the exact location in the rear for your gas tank, but generally if you set the top of the tank even with the top of the frame rails you "should" be OK.
actually I was wanting to raise it just above flush...say about 1.5 inches. The tank is 7.5 thick. It's a donor aluminum.
The frame is right at 6" with the 7.5 I could build a bottom brace and set the tank on straps....if I have a couple of inches to play with between the top of the frame to the bottom of the boards.
Not a great picture, but this is what I'm working with...and believe me it aint that ugly anymore...I need to get a new pic...
http://flic.kr/p/9m4TV9
thanks for the reply...
Hank Flowers
Cut and Shoot Texas
1952 3/4 Ton 3600
Just curious...whats the tank out of.......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
a boat...and believe that's all I know...other than it is currently rated for 27 gallons.
I'll have to cut it down a bit to fit in between the rails...no biggie though
It's as clean as a church in there and it has an internal baffle.
I have fit a new sending unit and cleaned up all the plumbing and buffed the tank..it looks pretty darn good now..
Hank Flowers
Cut and Shoot Texas
1952 3/4 Ton 3600
