4 members (thekid1950, Hotrod Lincoln, RoadsScholar, 53 green 1- ton), 149 guests, and 1 robot.
Topics128,080
Posts1,056,064
Members48,433
#726473 03/04/2011 4:16 AM
Can anyone tell me how to remove the back glass from a '37 P/u?
Double posts won't get better answers.
Sorry, I'm new
Hi Greg, I'm a glass guy to trade but have never worked on a '37,do you have any pics?
More pix on Flickr.
If it is like my '40, metal frame on outside has screws on inside of metal cab liner. Remove screws and metal piece - may take a little prying so be gentle. That leaves rubber gasket which I ended up cutting out with an Xacto knife ( rubber was so old and PO had glued on top to stop leaks )
1940 Chevy KC 1/2-Ton
It sounds similar to the set-up used on some boats/ships,but obviously smaller...... grin
More pix on Flickr.
It comes out from the inside after you remove the outside ring (be nice to that ring it is expensive from what I hear)If it has not been glued you should be able to riggle the seal and glass out.
1937 Chevy 1/2-Ton
