| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | Can anyone tell me how to remove the back glass from a '37 P/u? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Double posts won't get better answers. | | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Greg, I'm a glass guy to trade but have never worked on a '37,do you have any pics? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If it is like my '40, metal frame on outside has screws on inside of metal cab liner. Remove screws and metal piece - may take a little prying so be gentle. That leaves rubber gasket which I ended up cutting out with an Xacto knife ( rubber was so old and PO had glued on top to stop leaks ) | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | If it is like my '40, metal frame on outside has screws on inside of metal cab liner. Remove screws and metal piece - may take a little prying so be gentle. That leaves rubber gasket which I ended up cutting out with an Xacto knife ( rubber was so old and PO had glued on top to stop leaks ) It sounds similar to the set-up used on some boats/ships,but obviously smaller......  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | It comes out from the inside after you remove the outside ring (be nice to that ring it is expensive from what I hear)If it has not been glued you should be able to riggle the seal and glass out. | | |
