0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | hi all working on my 62 235 doner motor and need the oil line that goes on the center of the rocker arm shaft , mine has a few digs ,where can you find them ? adam | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brad, What would be the part number at Chevs of the 40s? Adam, Are you referring to the oil connector (1954) in the middle of the two rocker-arm bars, which changed over the years (1959)? You will need the style of connector that matches the year of of your rocker-arm assembly, that hopefully matches the year of your head (that hopefully matches the oil-supply plumbing on the year of your block). If everything is from 1962, you will most likely want a connector as shown from in the 1959 manual (I'll check later manuals tonight). When Pre '68 Dave sees this, he'll correct and clarify what would be needed in 1962. | | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | Brad Yes it's on the middle rocker arm support where the two shafts meet, the one that I have looks like someone pinched it with a pair of pliers. block #3769716 head #3835913
adam | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The rocker arm shaft connector is the same from 59-62.
Early part # was 3764478 later # is 3779879.
Pinching it with a pair of pliers was not uncommon.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | Tom Pinching it to change presure/ flow both ? do I replace it ? new to the hobby.
Adam | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1959-62 will be pinched off from the factory to give full pressure to the shafts, before that there is an over flow tube. I would check your rockers to make sure they are 1959-62. The groove inside each rocker should be offset 1/4" from center. If the groove is centered let me know. If you can't find a connector PM me, I can help.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Adam, It looks like you have a 58-63 block and a 54-55 head. Would you please post your head date casting code? You might want to also post a link to a photo of your connector. It could be the earlier style I posted above - which style of connector does it look like (1954 or 1959)? If yours is like the one in 1954, I have seen almost all of these pinched a little at the outflow tube (perhaps to increase pressure a little?). | | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | Here a pic of my the oil connector [url=http://i1230.photobucket.com/albums/ee481/MasterMichael1998/DSCF5156.jpg][/url] head casting # 3835913, date code L84, and the groves are in the center of the rocker arms.
Thanks Adam | | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | sorry the link did work , the oil connector looks just like the one from the 1954 from post above, only pinched off.
adam | | |
