4 members (TUTS 59, dt235sd, cmayna, 1 invisible), 70 guests, and 4 robots.
Topics128,176
Posts1,057,122
Members48,463
I'm in sort of a jam, I got this front axle given to me, guy thought it was off of a 54 chevy 1/2 ton. When I got it it was seized up, would not turn spindles (stear)at all. I took it apart with no problems at all, the problem is the kingpin is standard size .866, BUT the bushing is big 1.087, standard is 1.051. Nothing is worn at all, all tight, maybe too tight, that's why it was seized. There is not a groove cut in the outside of the bushing but there is a small groove cut in the inside. At this rate the bushing is .036 over standard, could this be a homemade bushing? Does anyone have any idea how to proceed from here, I don't think I can reuse them as one of them was damaged during removal. Are the spindles off of my 41 the same, could I use the 41 spindles on the 54 axle, the 41 axle would need oversize kinpins.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Z
Z Offline
Would a kingpin rebuild kit work? maybe even the .10 over set? i am not used to the kingpin setup.. yet.
52 Chevy 1/2 ton - work in progress
65 Mustang coupe - work not in progress smile
67 Mustang GT convertibile
67 Camaro RS/SS
We are now even with fords and chevys. smile
Now i need a mopar. Hahahahahahahahaha
I have a kit and it's not right. I can get a .010 over pin or a .015 over bushing, BUT NEITHER will work. This bushing is .036 over on the O.D. Dave
1941 Chevy
Make your own bushings, or find spindles that are in spec.
Sounds like someone cleaned up some worn oversize bores and made some bushings the last time.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Contact Sid at Sid's Axle's or Nostalgia Sid's. I am not good at links but search for him in the forum or Google one of those names. I found him to be very helpful and ready to give good advice based on lots of experience. I am very pleased with the work he did on my spindles and the other parts I got from him.
Chuck
Either have a bushing made to fit a standard king pin or find another spindle. 51-56 Chev and 51-52 GMC all use the same spindle.
I know this advise is rather basic, but when you do get
a bushing that does fit your spindles, notice the small
hole in the side of the bushing. This hole must line up
with the greage zerk opening in the spindle in order to
lubricate the assembly. Also, don't forget that the
thrust bearing can be installed upsidedown so be carefull
and get it right in the first place. Use as many spacer-
shims as necessary to eleminate axle to spindle verticle
movement. Use a new grease zerk, and be sure grease will
travel through the spindle before assembly, Good luck.
Have any problems, ask, we are here to help.....
I'm headed to the machine shop today. Dave
1941 Chevy
