| | | Forums66 Topics128,093 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | I just received a new back glass and weatherstrip. How do I replace the glass? I removed the screws inside around the window. It doesn't want to move. Is it just stuck? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Not sure about the truck back glass but the car weatherstrip has a channel for the glass and a lip that fits over the flange that runs the circumference of the window opening. If you're not going to try to save the old weatherstrip you'll probably have to cut it out. If you've not done one before and aren't sure how it's installed you'll be ahead to at least call and talk with a glass pro.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | First, congratulations on getting all the screws out of the pot metal trim ring, most have at least one that breaks or the pot metal threaded boss it fit into crumbles. I did mine before it was painted so I had better options over one with the final finish on it. We used two heat guns, one on the trim ring and the other on the inner cab panel and also used longer screws so we could work our way around and around pushing on them in turn as the heat built up. It was really stuck but finally started to let loose in several areas so one could work each direction from those areas. That trim ring is fragile after 74 years and also rare and pricey if broken. After it's off you will see that it is the screw bosses (towers) that hold the ring in position, not the screws.
Evan
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't know about a '37 specifically but most old rubber glass seals are to hard to remove without cutting them off. | | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | Thanks Evan. I was also amazed that all of the screws were easily removed. I'll try the heat gun method. | | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | Use some cardboard and make a pattern of the glass incase you break it. Its cheap to replace.
Joe | | |
