8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Hello all, I am missing a few screws that hold the top of the carb where the air cleaner attaches to the bottom of the carb where it bolts to the intake. I tried matching these in a hardware store but the thread wasn't anything they carried. Someone told me Rochester used a special thread unique to their company. If this is true where can I get these screws from? Thanks In advance, Dave
| | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | There is a good chance the motor or carb aren't original. I thought I tried all of the screws at the local hardware store but maybe I didn't. I think you understood me on where the 4 screws are at. The screws go through the piece that the air cleaner also attach to. I will try and track some 12-24 screws down at the local hardware store. Is a 12 series screw the same as a 3/16?
Thanks, Dave | | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | Here's a bit more trivia for you- - - -When GM decided to produce their own carburetor for the Chevy engine, it was a major financial blow to Carter. The Carter CEO vowed to produce one million replacement carbs for Chevrolet engines and sell them through their authorized distributor network, including my father's shop. A few years later, Carter had the one-millionth carb of that series gold-plated, and presented it to GM's CEO.
"The ABC's of carburetion- - - -Always Buy Carter" was their slogan for a long time. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Thanks to Hotrod for that little bit of history. That is fascinating.
In 1952 I believe it was, GM beefed up the Rochester B top a little. The Four screws were a size bigger and the metal under the screws was quite a bit thicker. | | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Thanks everyone, I will head out and get those screws today. I can't remember who told me that the rochester carb had their own unique thread but they sounded very convincing! | | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Bad news...just came back from the hardware store and the bolt I have is not a 12-24. It screwed a half turn in a 12-24 nut before the threads bound up. The guy used his thread pitch gauge and told me there were 28 threads per inch. Does this make sense to anyone? If you hold my bolt next to a 12-24 mine is a tiny bit more fine thread. Help! | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | 1950 and early 1951 carbs used a 10 x 32 thread. Late 1951 the thread was changed to 12 x 28.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Denny, I have in front of me my GM manual on the new carburetors for 1952, publication #MTS-52-8 &9-S&M. Quoting from page 2 "For 1952, Chevrolet introduces a new improved GM Model B carburetor. Externally, this new carburetor has larger air horn screws, a thicker flange and heavier bosses. There are numerous internal improvements." I have the earlier carburetor and the 1952 model and with my units, the screws are larger on the 52.
| | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Where can I get 12-28 thread screws from? | | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Where could I buy a 12-28 screw? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
