1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 10 New Guy | | New Guy Joined: Feb 2011 Posts: 10 | anyone ever replace the speedo needle? mine broke off inside the unit. is it hard to replace or should I consider replacing the whole unit? really don't want to as it is an all original 50K mile truck | | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | fix it yourself. It's so easy (did it in my '51) and its $5.00 vs $175+. 1. Unscrew the speedo cable, 2. pull out the guage lights (grab the metal, not the wires, 3. undo the four small nuts holding the guage in the dash (they're tough to reach). They might be finger nuts (round and finger tight) or actual nuts. 4. remove guage 5. the bezel is just bent over the guage (use a screw driver to bend the tabs out. 6. once the bezel is off, careful, glass will fall out. 7. gently pull the needle off 8. do the opposite.
I also replaced the glass since it was out. Cheers
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | https://picasaweb.google.com/wmhatfield/SpeedoWork#The hardest part of this whole job is getting the speedo out of the dash! Man that sucked!
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Keep in mind that replacement needles do not include the part that actual fits onto the shaft so don't throw anything away until you get your replacement needle. Concur w/Bigtonka, the hardest part is getting it out of the dash!
Ed
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Keep in mind that replacement needles do not include the part that actual fits onto the shaft so don't throw anything away until you get your replacement needle. Concur w/Bigtonka, the hardest part is getting it out of the dash! Hmmmm - my replacement needle came with it... you mean the silver disc right?? https://picasaweb.google.com/wmhatfield/SpeedoWork#5527351011778224930 | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You may want to consider new gaskets or substitutes for the bezel to glass fit since the old ones will be dried and probably fall out when you open it. Most of the vendors carry them. For those nuts (yes they are hard to reach) I bought one of these. Craftsman 6 in. Flex Spinner, 1/4 in. Drive Sears Item# 00904355000 | Model# 04355 Just enough flex you can get around some of the stuff under there. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I found giving a little counter clockwise twisting force while pulling on the needle, worked for me. Mine came with thecentre too.
Getting it out of the dash: This is one of the few times I may have said bad things about my truck! | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i used a white square plastic toothpick. cut it to the proper length and used black rtv to hold it in place. no one notices the needle until i tell them and they cant believe how good it looks like the real thing. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I was talking about the hub that actually goes on to the shaft that protrudes from the speedo. The silver disc has tangs that wrap around the hub. Sorry for the confusion
Ed
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I was talking about the hub that actually goes on to the shaft that protrudes from the speedo. The silver disc has tangs that wrap around the hub. Sorry for the confusion Ah yes - correct you are... and bending those tabs sucked too! :P Labor of love! | | |
