3 members (David Bush, mk72, Bill Hanlon), 130 guests, and 4 robots.
Topics128,053
Posts1,055,777
#725907 03/02/2011 4:29 PM
hi all
working on my 62 235 doner motor and need the oil line that goes on the center of the rocker arm shaft , mine has a few digs ,where can you find them ?
adam
olddog38 #725909 03/02/2011 4:34 PM
Chev's of the 40's
Brad Allen #725918 03/02/2011 5:00 PM
Brad,
What would be the part number at Chevs of the 40s?
Adam,
Are you referring to the oil connector (1954) in the middle of the two rocker-arm bars, which changed over the years (1959)?
You will need the style of connector that matches the year of of your rocker-arm assembly, that hopefully matches the year of your head (that hopefully matches the oil-supply plumbing on the year of your block). If everything is from 1962, you will most likely want a connector as shown from in the 1959 manual (I'll check later manuals tonight).
When Pre '68 Dave sees this, he'll correct and clarify what would be needed in 1962.
tclederman #726007 03/02/2011 11:05 PM
Brad
Yes it's on the middle rocker arm support where the two shafts meet, the one that I have looks like someone pinched it with a pair of pliers.
block #3769716
head #3835913
adam
olddog38 #726021 03/03/2011 12:19 AM
The rocker arm shaft connector
is the same from 59-62.
Early part # was 3764478
later # is 3779879.
Pinching it with a pair of pliers was not uncommon.
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #726072 03/03/2011 3:01 AM
Tom
Pinching it to change presure/ flow both ? do I replace it ? new to the hobby.
Adam
olddog38 #726106 03/03/2011 4:26 AM
1959-62 will be pinched off from the factory to give full pressure to the shafts, before that there is an over flow tube.
I would check your rockers to make sure they are 1959-62. The groove inside each rocker should be offset 1/4" from center.
If the groove is centered let me know.
If you can't find a connector PM me, I can help.
My Blog
olddog38 #726107 03/03/2011 4:28 AM
Adam,
It looks like you have a 58-63 block and a 54-55 head.
Would you please post your head date casting code?
You might want to also post a link to a photo of your connector. It could be the earlier style I posted above - which style of connector does it look like (1954 or 1959)?
If yours is like the one in 1954, I have seen almost all of these pinched a little at the outflow tube (perhaps to increase pressure a little?).
tclederman #726469 03/04/2011 4:10 AM
Here a pic of my the oil connector
[url=http://i1230.photobucket.com/albums/ee481/MasterMichael1998/DSCF5156.jpg][/url]
head casting # 3835913, date code L84, and the groves are in the center of the rocker arms.
Thanks Adam
olddog38 #726472 03/04/2011 4:16 AM
sorry the link did work , the oil connector looks just like the one from the 1954 from post above, only pinched off.
adam
olddog38 #726482 03/04/2011 4:35 AM
Hi...Here is the link again. I know it works this time. Little computer challenged.
Adam
[IMG]http://i1230.photobucket.com/albums/ee481/MasterMichael1998/DSCF5156.jpg[/IMG]
