| | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72577 01/31/2007 3:40 AM | Joined: Jan 2006 Posts: 19 New Guy | | New Guy Joined: Jan 2006 Posts: 19 | Hello all,
I am installing a 305 in a 1960. The first question I have is where can I get motor mounts to install this engine? The second question I have is what else will I have to do to make this work?
Paul | | |
#72578 01/31/2007 3:56 AM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I'll assume it's a 1960 "Chevy". You can contact www.steelrubber.com they have just about every type of mount you can think of. IF you're putting the motor in a GMC the frame is slightly different. | | |
#72579 01/31/2007 4:04 AM | Joined: Jan 2006 Posts: 19 New Guy | | New Guy Joined: Jan 2006 Posts: 19 | Sorry - should have specified - a 1960 Chevy apache.
Paul | | |
#72580 02/01/2007 12:57 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Are you using a stick or automatic ? Send me a PM I have a bell houseing ,clutch , etc from a 61 Apache and I live in Southern Indiana
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
