3 members (dunfire, MikeE, carbking), 55 guests, and 1 robot.
Topics128,129
Posts1,056,360
Members48,441
They are supposed to be straight, right? How bout the tie rod?
I just got an axle that I was going to have blasted, and it looks as if someone has bent it in the shape of a bow, with the middle being arched about an inch forward and the eyes about an inch back. Is this correct???
NO, it should be straight.
I
I Offline
I still have a big 1 1/2 ton axle if you can use it
Greg, are there any legibile numbers on that axle I could reference?
Sounds like someone hit a boulder.
Isn't MOR-DROP near you? Maybe they have a stock axle you can get cheap.
Paint & Body Shop moderator
Mor-Drop is in Oakland,ca. I bought my 4" drop from him,that guy has a hell of a shop. Old time blacksmith,,its really cool to see how he does it.
If i remember correctly, the axle and new king pins fit in it,,400.00 more or less.
I'll be buying another one from him for my other '54.
Marty
You know what? I questioned this myself with my front axle on my 1940 1/2 ton, because my axle is also bowed towards the front. I placed a straight edge along the centres of the kingpin holes, and measured from the straight edge to the u-bolt holes. Both sides measured up so close to each other that I am only going to assume that this is the way it should be and I am going to work with what I have. I also checked my axle over very closely and I could not find any visible mark or ding where it may have smacked anything.
Brian
I'm pretty certain that it is not factory. I never noticed that on another axle. I think it is the result of an allignment shop.
