0 members (),
122
Mod | | | Forums66 Topics128,131 Posts1,056,727 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 13 New Guy | | New Guy Joined: Apr 2010 Posts: 13 | I would like to change out this 3speed trans to auto trans. I want to know if a 350(auto)trans will fit this straight 6 engine. If not what do I have to do to get started, thanks in advance for your help. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | You should be good to go. The 350 trans will bolt up to the 230/250/292 series of engines. You can use the same shifter on your column, but you need a couple of pieces to make it work. You can get a Lokar cable shift linkage to make it easier on you. or you can fabricate a rod to make it work. Yiou can probably get a floor shifter for the trans as well if you want to get it done quick and dirty. You may want to call a place like Langdon's or an old-time trans guy. They can tell you what you should be using for a stall speed on your converter. | | | | | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Does it bolt up to a 235?
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | No. You'll see that the trans has the inverted "V" at the top. That is for a V-8 bell housing or the 230/25/292 series of engines. An adapter plate is available from the likes of Bendtsen's Transmissions or Langdon's for the 235 to later transmissions. The Langdon's kit seems to be a much better deal. But it's still over 400 bucks. ANYTHING can be done. It's just always how do you want to spend to do it? | | |
