0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
I would like to change out this 3speed trans to auto trans. I want to know if a 350(auto)trans will fit this straight 6 engine. If not what do I have to do to get started, thanks in advance for your help.
k10 Offline
You should be good to go. The 350 trans will bolt up to the 230/250/292 series of engines. You can use the same shifter on your column, but you need a couple of pieces to make it work. You can get a Lokar cable shift linkage to make it easier on you. or you can fabricate a rod to make it work. Yiou can probably get a floor shifter for the trans as well if you want to get it done quick and dirty.
You may want to call a place like Langdon's or an old-time trans guy. They can tell you what you should be using for a stall speed on your converter.
Does it bolt up to a 235?
Thanks,as always -Danny
1960 C-10 Stepside,Longbox
235,4spd 3.90 diff.
k10 Offline
No. You'll see that the trans has the inverted "V" at the top. That is for a V-8 bell housing or the 230/25/292 series of engines. An adapter plate is available from the likes of Bendtsen's Transmissions or Langdon's for the 235 to later transmissions. The Langdon's kit seems to be a much better deal. But it's still over 400 bucks. ANYTHING can be done. It's just always how do you want to spend to do it?
