| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | I am working on a motor swap and want to clean up the frame and what ever I can get too while the motor is out. What and how is a good way to remove general build up from the frame and other painted surfaces. The paint is in good shape so I just want to clean the surface, don't need to get to bare metal.
Thanks, Charlie | | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | A simple degreaser, Castrol, Simple Green, Dawn dish soap, etc... and a power washer. Car washes also work great for this since they have hot water, or find someone with a steam cleaner. Joe | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used spray on degreaser and a putty knife. For the tough spots a little acetone and 3M pads with lots of elbow grease. Lots of old disposable rags to soak up the mess. | | |
