| | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Putting together a '36 1 1/2 ton that the previous owner took completely apart. The front fenders are seperated from the inner engine compartment "skirts". What I can't figure out is if there is a piece missing that gives the hood something to land against where it meets the fender ? Many years ago I has a '37 and seem to remember a lip that stood up behind the hood from the fender edge. Hope someone has one and can take a look. Thanks, David | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | nope, nothing against the fender that I recall.. the hood latches against a tab that hangs off the lower edge of the fire wall, and then a spot on the lower grill shell I dont have any good pictures of when mine was assembled... I did find a picture that shows the lower latch point on the fire wall.. let me know if you would like to see that and I will post it up for u | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Thanks Corpo, that works. I've got the latches and all but didn't figure that the center area just flapped around. Glad I'm not missing a part. Thanks. | | |
