1 members (Eisenholtz), 59 guests, and 3 robots.
Topics128,022
Posts1,055,377
Members48,422
#725350 02/28/2011 7:27 PM
On an SM 465, can you unbolt a pto from one side of the trans and bolt it to the other side? Will the gears mesh correctly? Or do you need a different cut gear?
Thanks guys for the info!
1937 Chevy (converted to 4x4)
1942 Chevy G506 1.5 ton 4x4
1958 Mack B model (on Chevy 1 ton 4x4 frame)
1969 Dodge Charger
1987 K30 Crewcab
Bodyguy #725429 03/01/2011 1:03 AM
the gears should still match but the output shaft will now be on the top and the lever arm will be on the bottom.
51 ashton #725603 03/01/2011 4:54 PM
Either top will become bottom as stated, or the front and back of the PTO will be swapped. Not too bad if it has shafts both front and back but a problem if there's only one shaft and it now faces the wrong end of the truck.
Grant_Bowker #725657 03/01/2011 7:52 PM
The PTO must be assembled differently and that can only be done on double gear units. If yours is a single gear then the short answer is no.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #725814 03/02/2011 5:11 AM
It is a single gear. And after further inspection, I see what you guys are saying. The gear is now in the front instead of the back. However, I think I can relocate the pillow bearing to get it to work on that side.
FYI - I'm putting the SM465 in a 42 G506 dump. I'm not even sure what the stock trans is - but it had a PTO on the drivers side and the SM465 had it on the passenger side. The PTO on the stock trans is the same bolt pattern as the SM465 but it has a strait cut gear so that won't work. However, I think I may have it figured out now with some minor fab work.
Thanks for the info, guys.
Jeff
1969 Dodge Charger
1987 K30 Crewcab
Bodyguy #725938 03/02/2011 6:14 PM
ALL of the PTO openings are SAE 6 bolt on the older transmissions. Larger HD transmissions may also SAE 8 bolt openings.
Dave
