6 members (MickeyP, cmayna, Donf, Peggy M, Lightholder's Dad, 1 invisible), 126 guests, and 2 robots.
Topics128,092
Posts1,056,457
Members48,443
Bought a 235 w/crack in exhaust manafold and no carb. Any reason why I can't use the 216 intake and exhaust and carb? 1952- 216 1959- 235
'52 3100 "once a Marine, always a Marine!!
I do it all the time.
The port size is smaller on the 216 so you need to use adapter alignment rings, or no rings at all, and take time to align.
My Blog
Thanks, that'll save me a bunch!!!!
Pre 68Dave,
what do you do for a carburetor in this setup? I am going to guess that you rejet a 216 carb.
1951 1 Ton Completed
Dave, how do you put things together without the alignment rings? Thanks Don
Originally Posted by truckernix
Pre 68Dave,
I have a steep hill I test all of the 235s I work on and I have seen no adverse affect from running a 216 carb. with 216 jetting.
From 1941-49 the big trucks with splash 235s used 216 carbs and manifolds from the factory.
Don, I make my own alignment ring adapters but I know a lot of people leave the rings out.
I would glue the gaskets to the head to keep them lined up, and center the manifold , if your not using rings.
My Blog
V
V Offline
I 2nd what Dave has suggested.
Before you decide to use the 216, and if you are going to use the 235 carb (Which I did), make sure the 235 is not 2and 15/16".
I was going to use a two carb offenhauser manifold on my 1961 engine. It was designed for 2 and 15/16, I sold the "Offy" and stayed with the original 235 cast iron intake and exhaust. Glued the gaskets to the head, done away with the "alignment rings", bolted everything back together, started her up, have had no leaks yet.
