8 members (Gdads51, Otto Skorzeny, warlock, RoadsScholar, Ponchogl, 55shaker, k2handyman, 5 Window 9434),
104
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | I just rebuilt my 6 volt starter with new brushes,new contact switch ,turned the commutator and did some repair on the fork. Most of the time it works but sometimes it "just zings" without engaging. Any suggestions? Jeff | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You didnt say anything about the starter drive. You probably need a new one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy coolchevy, did you replace the starter drive? It sounds like it is not working all the time. The other thing that can happen is, the drive does not mesh with the flywheel teeth, but the action of your foot on the starter pedal closes the switch contacts on the motor making it spin. You should check your flywheel teeth for burrs that may be stopping the engagement of the starter drive with the flywheel, hope that helps. | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Ah Ha ! I didn't replace the starter drive. And it looked a little worn.I will remove the starter and see if I can find a new starter drive locally. Thanks! | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Well I replaced the starter drive and everything seems fine. So far so good. It is too cold here to keep on testing it. I'll keep you posted Thanks ! | | |
