3 members (Hanks custodian, wilbur53, 1 invisible), 110 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
#724573 02/26/2011 5:44 AM
I did a search for this and didn't turn up any results so sorry if this is a repeat.
What pressure reading should a 1954 235 have? I've had my truck put up the last couple of months while I put the new suspension in. While test driving the new ride, I looked over all the gauges and the oil pressure looked low. Granted, it's not pin point accurate on the old 54 gauges but the needle was slightly below the mid point. Closer to the 1/4 point. Thoughts?
brandon s.
1954 Chevrolet 3100 1/2 ton
Wanna see it?
Walburg, TX
Since they don't have hydraulic lifters any pressure that keeps them from knocking/rattling/or squeeking is enough. The rockers usually starve first so pull the cover and see if oil oozes (it never squirts) off the rockers. If it does, drive it.
Evan
I am some what guessing but 30-35 at start up and 20-25 as the oil thins out and about 10 when idling.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Most of the 235s I have seen run 30 on the highway and idle at 15, when warm.
As bearing clearances open up with wear over time, the pressure will drop.
My Blog
Thanks for the help!
brandon s.
Wanna see it?
Walburg, TX
