7 members (RdsLessTaken, TUTS 59, Jay R, Otto Skorzeny, 68ironhead, Phak1, 1 invisible),
99
Mod | | | Forums66 Topics128,136 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 20 New Guy | | New Guy Joined: Feb 2011 Posts: 20 | Hi, I have a '48 half ton w/ original 4 speed tranny and torque tube. When I push the clutch in, there's a grinding sound.Once i'm under way it shifts fine. I believe it needs a new throw out bearing and clutch. My question is do I have to remove the rear end to do this? I have heard that this can be a real pain. I'm mechanically inclined, but, i don't know if I can pull this off in the driveway by myself. Thank you in advance to anyone that can give me some info on this, Keenan
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i have all open drivelines but the sequence is the same. drop shaft or dissconect it. disconnect spring and clutch fork, remove floor pan, support/hang tranny and unbolt it and slide far enough to clear and unbolt pressure plate. check pilot bearing in the end of the crankshaft replace if needed. install new clutch pressue place and throwout bearing. you can use a pilot shaft alignment tool for lining up the disc with the pp. or you can just use the tranny itself. after tranny is in just complete the rest of the process in reverse. adjust clutch pedal for proper freeplay and go for a test ride over to point loma and back. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Keenan, at the front of the torque tube is a collar you need to release by turning off. Then you tap (bang) the yoke back to expose the U joint, unfasten it and you are good to go.
Oh, and welcome to the site.
Leo | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | This is not that hard of a job except the trans is heavy. Remove the 4 bolts that holding the ball at the rear of the trans. Then slid the coller back like Panel said. Then remove the bolts on the u-joint. The drive shaft can be lowered down or tied up above. Then procede as in any clutch job. To remove the gearshift lever, push down on the coller on top the tower with pliers & turn it about 1/8 turn CCW. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | ironic that you just posted this. mine just went out on the way to work today. fun, fun, fun.....!I'm going to have to do mine in the driveway/garage too. good luck to you if you haven't already done it. -DVZ | | | | | Joined: Feb 2004 Posts: 29,818 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | One precaution when jacking the vehicle up- - - - -put the jack stands under the frame, not the rear end housing. If you don't let the rear end hang free without weight on the springs, the torque tube can slam down violently as you unbolt it. If you happen to be under it at the time, it can hurt you. A friend back in high school learned that lesson the hard way! Jerry
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | As mentioned the SM-420 is heavy they weigh 135 lbs so get some help or use a picker in the door to support it. It is and awkward place to try and man handle that much weight. | | |
