| | | Forums66 Topics128,051 Posts1,055,762 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | What kind of 4X4 axle would fit on my 1959 GMC truck? i would like to make it 4x4 | | | | | Joined: Apr 2007 Posts: 456 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 456 | Find NAPCO running gear and convert your truck to 4x4 in about 3 hours... that's what the brochure said. I've done it by myself in a couple days. Now that I've done it a couple times, I figure I could get it done in about 5 hours.
George | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | George is right. It is the easiest way. | | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | were am i going to find that , you dont find these truck at every corner up here | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Find on internet and pay for shipping. In AZ about $2000-$3000 for complete chaissis/drivtrain. You know you need the axle, springs (front and back) transfer case and mounting, front drive shaft, shifter lever. And about $1000 to ship to Canada. If you have the money I will find you one. I have converted one to 4X4 but prefered the modern drivetrain (more than 5 hrs, more than couple days) But more reliable and open knuckles and 205NP case (the best available stock case). Easier to find modern stuff and cheaper and modern bearings, etc.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Napco 4x4. Check this site out. Lots fo good information on Napco and other early GM 4x4s, plus there's a classified section that does have several complete and parts Napco trucks listed. To add to what bartamos said, going late model will be easienst as far as aquiring parts, but the late model axles will be wider that the Napco axles. Plus there will be some fabrication involved to adapt the steering box and a mount for the 'case.
Bill Burmeister | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Beausejour, there is a great article in this month's Vintage Truck mag about a 55 (second series) Napco Suburban. Great information. Hey George (Napco man), is that yours by chance? That truck is Sweeeet!! (putting two and two together ?)
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Out of curiosity, would an axle/t-case out of a Jeep Wrangler work in the older trucks? I was thinking they would be narrow enough with much after market support. Or are they too weak? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It might work, would have to measure one to be sure. If you were to use one, get it out of a Rubicon edition Wrangler, they use Dana 44s instead of the 35, which would be far too weak for full size truck, plus they have a much stronger t-case. You would want both axles, not only to keep the gears right, but to have matched brakes and wheel bolt pattern (5 x 4.5). Personally, if I were to build one (an I did consider it, even had a bare chassis spotted at a local salvage yard), I would look for either a 3/4 ton Dana 44/ Corp. 14 bolt or a 1 ton Dana 60/Corp. 14 bolt combo with either an NP 205 or 203 t-case. I know it's overkill, but like they said in the first Cannonball Run movie, "If you're going to be a bear, be a Grizzly!".
Bill Burmeister | | | | | Joined: Apr 2007 Posts: 456 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 456 | Yes, that is my suburban in Vintage Truck and thanks for the compliments.
George | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | My 53 was put on a 69 jeep wagoner frame with a 4x4 setup by the previous owner. They entire drivetrain was jeep. Sold the entire frame and drivetrain to a gentleman in N.Carolina that wante to convert his 52 to a 4x4
| | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | ive got my 1953 on a 1964 chevy truck 4x4 frame. tires are are not really wide but fit under the truck pretty good.maybe use a 4x4 axle from the 60s.and i too have seen people use a jeep set up and the tires didnt stick out too bad | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | or have an axle built to the width that you want.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | or have an axle built to the width that you want. That can get expensive, depending on what you have built into the axle (gear ratio, lockers, etc). Last I checked, you'ld be looking at around $1500 for a basic open steer axle. If you're looking to do any sort of off roading or possibly plowing, might be worth it, though. Another option would be to narrow the axle(s) yourself, if you have the necessary skills. You might take a look at 4X4 Xtreme on the Power Block website. Ian Johnson has done several axle conversions like this, mostly using Dana 60s, but the concept is the same.
