6 members (Uncles51, Peggy M, dwreills, JW51, Millenimech, Chip O), 41 guests, and 1 robot.
Topics128,035
Posts1,055,446
Members48,422
#723223 02/22/2011 2:42 AM
I'm planning and figuring and trying to come up with a front axle swap and disc brake conversion for single wheel 1 ton (and 3/4) trucks.
Need to know how wide the edge of tires can be and still look like they fit under the front fenders.
So, how wide is yours, and what does it look like??
How much wider could it be and still look OK?
I already know that the stock 1 ton single wheel FRONT axle measures approximately 58.25" from Wheel Mounting Surface to WMS. I want to know how wide I can get away with.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Some measurements from my 52 1 ton (no axle right now)
With across front fenders at top center is 72.25"
Width inside fender lip at bottom of opening both front and back is 68"
Width outside rear edge of opening at the bottom is 70.5"
So I'm guessing outside of sidewall to sidewall could be 68" and look great, and might could be 70" and be OK.
Can someone please lay some straight edges on the outside of your tires and measure the overall width and also comment on how much wider you think it could be and still fit and look OK?
Grigg
---All pictures---
Grigg
You need to get a hold of John and have Him Measure up The FLAGSHIP Truck,as it,s the most Unmolested 3800,1 ton single wheeler I,ve seen.
regards,
Steve sr.
My '49 3800 front axle measures 64" to the outside of the sidewalls with 8r-19.5 tires. I think I could be comfortable with up to 2" wider on each side, but no more than that. Just my own opinion.
Steve
'49 3800
'52 3600
'57 3100
Excellent!
Thanks for the info, and I'll nudge John to measure his too.
So far all looks good, I think this disc brake plan should work out.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=723646#Post723646
Grigg
---All pictures---
62401
Grigg -- Measurements off Ole Charlie:
In stock configuration, running 7.50x19 tires
Outside of sidewall to outside of sidewall: 65 11/16"
Top of wheel sidewall to fender opening (top): 3 1/2"
Turning clearances
front of fender opening: 2 1/2"
Back of fender opening: 2"
At full throw (wheels at full turn), the tire is 1 3/4" from the rear springs (limiter at front is the shock (single action) and the clearance appeared to be 5 or 6 inches or more).
If you need more, let me know. Looks like I came within spittin' distance of Ghostrider's radial-equipped truck (beautiful truck BTW!) But I think you have less than 2 inches to play with before you run out of schlitz on the wheel opening.
Thanks for the support Steve Sr.!
Hope this helps.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderated by  Dusty53
