1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | Ok...let me word this differently. The frame from my 51' GMC 100 longbed has completed work as follows.... Mustang II front end suspension, rack and pinion steering, new 3:23 limited slip rear end gears, new leaf springs, 4 wheel disc brackes and frame is rust prepped and chassis painted. where would you go from here with the framework? Asking for suggestions. thank you for your imput
1951 GMC 3 window 100 1951 GMC 5 window 100
| | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | Not understanding the question?
If you are asking whats next, go with brake lines, fuel lines, any wiring that you can do. Install engine and trans and set up a cooling system so you can get engine running while its easy to get to. Once you have engine running, install the cab and start working out the steering column and how you are going to hook up to the rack and pinion.
Joe
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Don't know what your intentions are with your truck but if you contemplate lowering in in the future,This is the perfect time to notch the frame, even if you don't need it for a few years.
| | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | Joe,
Yes, that's what I wanted to know. Pretty much had it that way. thanks
How do you notch the frame?
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well, it isn't really hard. find some pics and either order a bolt in or weld in notch. I fabbed my own after looking at others. P.m. me if I can help in any way. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Short of coming to California. :>) | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | Ha! you're welcome anytime!!!!
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | sent u a pm and got the word Hi back??
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | never got back, someone tell him I'm not a lurker. | | |
