2 members (Gdads51, moparguy), 96 guests, and 2 robots.
Topics128,180
Posts1,057,068
Members48,460
Trying to find a shop that can rebuild my Carter yf.The Carb Shop in Cal. says too busy and does'nt do singles any more.Any body have any info, this one needs a new bar fitted into it and I guess milling and drilling?? Thanks, Paul
Paul,
If S.C. means Southern California I can hook you up with a guy in San Pedro that has been doing carbs for 40+ years. It's a walk in type arrangement and he won't ship.
Fred 562-225-5969
rfs56trk; sorry for not getting back sooner, Comp. been down. S.C. here is South Carolina. I'm a Jersey trans plant.But there's got to be aomeplace where they'll do this Carter. Realy not to sure about this Rodcherter that's comming back from CD. I know they'll say it was something I did. Tank is CLEAN ans BRIGHT, 2 new filtere, befor and after pump.Just no cofedence in this Rodchester from what I've been reading....Any 2cents of info would be app. I'm watting for CD to return my new rebuilt, rebuilt, carb,working this time....Thanks , Paul
I have used both and they generally work fine. One of the main problems with 50+ year old carburetors is the shafts are worn. A good rebuilder can correct this problem.
Fred
I recently used "Recarbco" in the SF Bay area of California. They were not cheap, but my truck now runs like a million bucks. www.recarbco.com good luck
Lead, follow, or get outa the way. 50 Chevy 5 window, 65 chevy panel
