0 members (),
132
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Trying to find a shop that can rebuild my Carter yf.The Carb Shop in Cal. says too busy and does'nt do singles any more.Any body have any info, this one needs a new bar fitted into it and I guess milling and drilling?? Thanks, Paul | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | Paul, If S.C. means Southern California I can hook you up with a guy in San Pedro that has been doing carbs for 40+ years. It's a walk in type arrangement and he won't ship. Fred 562-225-5969
| | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | rfs56trk; sorry for not getting back sooner, Comp. been down. S.C. here is South Carolina. I'm a Jersey trans plant.But there's got to be aomeplace where they'll do this Carter. Realy not to sure about this Rodcherter that's comming back from CD. I know they'll say it was something I did. Tank is CLEAN ans BRIGHT, 2 new filtere, befor and after pump.Just no cofedence in this Rodchester from what I've been reading....Any 2cents of info would be app. I'm watting for CD to return my new rebuilt, rebuilt, carb,working this time....Thanks , Paul | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | I have used both and they generally work fine. One of the main problems with 50+ year old carburetors is the shafts are worn. A good rebuilder can correct this problem. Fred
| | | | | Joined: Dec 2006 Posts: 11 New Guy | | New Guy Joined: Dec 2006 Posts: 11 | I recently used "Recarbco" in the SF Bay area of California. They were not cheap, but my truck now runs like a million bucks. www.recarbco.com good luck
Lead, follow, or get outa the way. 50 Chevy 5 window, 65 chevy panel
