4 members (Guitplayer, MickeyP, Ponchogl, ShopRag), 90 guests, and 1 robot.
Topics128,035
Posts1,055,564
#722635 02/20/2011 5:16 AM
Taking my transmission apart, I found the flywheel bolts are not stock, except for one. Looking at it, it's a GR8 but with slots in the head instead of the usual raised marks. Doing some research with the parts manual, I found it is a GM type AA six slotted head GR 8 bolt with 300M steel. Searching in the net it seems AETNA makes these exact bolt. I'm assuming they won't sell me 6 units. Have any of you bought these bolts before or have you used standard Gr 8 bolts UNF?. Appreciate any help.
Check these out:
http://cgi.ebay.com/ebaymotors/ARP-...arts_Accessories&hash=item1c18324257
They're ARP brand bolts, which usually exceed Grade 8 strength. If the 7/16-20 thread is right, they should work as well as, or better than original equipment. They've also got the big, thin heads for good clutch hub clearance.
Summit Racing has these for $8.95. E-pay wanted $18.99.
Bob Giles #722682 02/20/2011 12:24 PM
Your local parts store should have those flywheel bolts. Dorman makes them as well as Mr. Gasket.
I found them on ebay, original GM
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
Mr.Giant #722930 02/21/2011 2:46 AM
I found Doorman, Mr Gasket and Arp bolts, and yes, they are cheap. I'm not really looking for the original bolts, since metallurgy on those days is not as good as today, but what caught my attention was the use of 300M steel (stated by the parts manual) which exceeds some specs of grade 8 standard material. Have you used them? Does the above bolts have the recessed shoulder also, or just the thin heads?
They should work fine for your truck. I have used the Dorman and the Mr. Gasket bolts both and they should fit as original.
I´m gonna try any of those, thanks. I'll post if Aetna answers, it should be a nice sort of original replacement.
