7 members (TUTS 59, Gray_Ghost, panic, tclederman, Peggy M, MRMEROTH11, Wickedbass),
122
0
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | Taking my transmission apart, I found the flywheel bolts are not stock, except for one. Looking at it, it's a GR8 but with slots in the head instead of the usual raised marks. Doing some research with the parts manual, I found it is a GM type AA six slotted head GR 8 bolt with 300M steel. Searching in the net it seems AETNA makes these exact bolt. I'm assuming they won't sell me 6 units. Have any of you bought these bolts before or have you used standard Gr 8 bolts UNF?. Appreciate any help. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Check these out: http://cgi.ebay.com/ebaymotors/ARP-...arts_Accessories&hash=item1c18324257They're ARP brand bolts, which usually exceed Grade 8 strength. If the 7/16-20 thread is right, they should work as well as, or better than original equipment. They've also got the big, thin heads for good clutch hub clearance. Jerry
| | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Summit Racing has these for $8.95. E-pay wanted $18.99. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Your local parts store should have those flywheel bolts. Dorman makes them as well as Mr. Gasket. | | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | I found them on ebay, original GM | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | I found Doorman, Mr Gasket and Arp bolts, and yes, they are cheap. I'm not really looking for the original bolts, since metallurgy on those days is not as good as today, but what caught my attention was the use of 300M steel (stated by the parts manual) which exceeds some specs of grade 8 standard material. Have you used them? Does the above bolts have the recessed shoulder also, or just the thin heads? | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | They should work fine for your truck. I have used the Dorman and the Mr. Gasket bolts both and they should fit as original. | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | I´m gonna try any of those, thanks. I'll post if Aetna answers, it should be a nice sort of original replacement. | | |
