| | | Forums66 Topics128,083 Posts1,056,326 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | How can I identify which series Eaton posi I have? It came out of a 65 C10. Thanks | | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | I called a driveline shop and they gave me the measurements. Stand the carrier on a bench with the ring gear flange up. A series 3 is 1.7" from bench to top of flange where the ring gear mounts. A series 4 is 1.945". | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I have tried to find out this info for some time, but no luck. My biggest question is, did the factory put 3:73 gears in a 4 series carrier? I have seen info in books that show only 3:73 and up were posi? | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I have 3.73 and it's not posi.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | They made them in single legs, yes, but did they ever install from the factory a3:55 - 3:08 or any thing lower than a 3:73 in a posi? You can get aftermarket 3:73 gears that fit a 4 series posi unit for this rearend, but I think from the factory the 3:73 and 4 series gears all used the same posi section. Does this make sense, or am I all messed up? | | |
