1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
How can I identify which series Eaton posi I have? It came out of a 65 C10. Thanks
I called a driveline shop and they gave me the measurements. Stand the carrier on a bench with the ring gear flange up. A series 3 is 1.7" from bench to top of flange where the ring gear mounts. A series 4 is 1.945".
I have tried to find out this info for some time, but no luck. My biggest question is, did the factory put 3:73 gears in a 4 series carrier? I have seen info in books that show only 3:73 and up were posi?
I have 3.73 and it's not posi.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
They made them in single legs, yes, but did they ever install from the factory a3:55 - 3:08 or any thing lower than a 3:73 in a posi? You can get aftermarket 3:73 gears that fit a 4 series posi unit for this rearend, but I think from the factory the 3:73 and 4 series gears all used the same posi section. Does this make sense, or am I all messed up?
