3 members (klhansen, ronsway, 1 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I have a 58-62 235 in my '53 3600 and am having a bit of trouble with it. I have an exhaust leak coming from 2 spots where the manifold meets the head. I plan on taking the manifold to a machine shop to get it trued but I am still paranoid. I read that the new gaskets are half as thick as NOS ones. Are there any places selling the properly thick gaskets?
Also, do I have to separate the intake and exhaust manifolds to have it trued? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I have had them together when getting them resufaced. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I bought the problem solver gasket from [censored] Larrowe. PSK-235-261 It's pretty impressive, nearly 3/16" thick. I didn't use it, though, the stock Fel-pro gasket worked fine. So all I have to go on is how it looks. regards, Leon | | | | | Joined: Jan 2011 Posts: 13 New Guy | | New Guy Joined: Jan 2011 Posts: 13 | I had the same problem when I up-dated my engine from a 1950 235 cu.in to a 1961 Cu.in. using the 1950 intake/exhaust manifolds. After dressing all the surface areas, and putting the manifolds back together, I just couldn`t get a proper seal. Finally I loosened the bolts and nuts which hold the exhaust to the intake manifold, re-alligned the manifolds to the block, tightened all the manifold bolts, and lastly, re- tightened the intake to exhaust manifold bolts. (solved the problem). | | |
