0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#717926 02/04/2011 12:03 AM
59 3100 with 235, just rebuilt carb and had a problem with fuel leaking at first solve that but now the truck wont start unless I dump fuel in the carb. Then it's fine and will actually restart after it warms up! Float adj prob?
phnman23 #717933 02/04/2011 12:15 AM
Sir Searchalot
Sir Searchalot
FLOAT, STUCK NEEDLE, GASKET LEAK OR ON BACKWARDS, FLOAT SETTING TOO LOW. BE SURE TO CHECK TO SEE GAS IN SQUIRTING INTO THROAT WHEN THROTTLE IS ACTUATED, REPORT BACK.
yep fuel squirting into throat but will not fire off on her own, until I dump some gas in the carb. Just changed points and plugs since I posted this afternoon ,no help. Runs fine after I get her going and after she warms up she will start on her own although not right off
Sir Searchalot
Sir Searchalot
If you pump the pedal and it squirts each time, then it's the same as poring gas in there!!!! Pump it 6 times and see if it squirts six times in a row, if yes it will start, if no, low float or weak/leaking seal accelerator pump. Make sure it's a two person test, no time to watch it squirt and then get in and turn it over. need observer and starter persons. Report back. report by email [email protected]
