| | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | 59 3100 with 235, just rebuilt carb and had a problem with fuel leaking at first solve that but now the truck wont start unless I dump fuel in the carb. Then it's fine and will actually restart after it warms up! Float adj prob? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | FLOAT, STUCK NEEDLE, GASKET LEAK OR ON BACKWARDS, FLOAT SETTING TOO LOW. BE SURE TO CHECK TO SEE GAS IN SQUIRTING INTO THROAT WHEN THROTTLE IS ACTUATED, REPORT BACK.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | yep fuel squirting into throat but will not fire off on her own, until I dump some gas in the carb. Just changed points and plugs since I posted this afternoon ,no help. Runs fine after I get her going and after she warms up she will start on her own although not right off | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you pump the pedal and it squirts each time, then it's the same as poring gas in there!!!! Pump it 6 times and see if it squirts six times in a row, if yes it will start, if no, low float or weak/leaking seal accelerator pump. Make sure it's a two person test, no time to watch it squirt and then get in and turn it over. need observer and starter persons. Report back. report by email [email protected]
