2 members (55shaker, Paul_WNC), 75 guests, and 1 robot.
Topics128,035
Posts1,055,552
#722836 02/20/2011 10:40 PM
1 Offline
When my truck comes back from the body shop, I'm going to relocate the gas tank to the rear (betweeen axle and bumper) to give myself more room in the cab. i've seen several people use blazer style tanks, and I've seen people use the generic type fuel cell from summit. Does anyone have any good advice on a fuel tank that fits with little modification and has a fairly convenient fuel filler location? If you have pics of your setup, it'd be incredibly helpful.
"Little modification".... well that means different things to different people.
Check out post #8 here: http://67-72chevytrucks.com/vboard/showthread.php?t=444378
1 Offline
By little modification, I really mean no welding to mount the tank. I've seen several of the straps that just require drilling and bolting. I expect to have to either create a fuel filler door in the bed or on the rear fender somewhere.
Moving the tank will create some changes to storage area under the rear frame. There are two things that I like about a welded S/S Tank. First there will be no cracking as with Aluminum or Poly tanks if you happen to drag bottom. The second thing you have to choose where you are and how you are going to get fuel into the tank may it be left,right through the bed or out the back. The next step which a lot of guys do not figure on is a filteration system incase the fueling station has sediment in their tanks or water in them. The filter I use in a 100 micron filter with a screen in which you can clean out by the tank. By using AN fittings it drops right out by your tank and you do not have trash in your line and fuel pump going up to your carb filter. The tank I have was made to bolt to your frame rails.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
