3 members (ronsway, NJC, dt235sd), 152 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#722572 02/20/2011 1:54 AM
Hi All,
Tried the 19.5 rims on my '36 1 1/2 ton and they DO NOT fit over the rear brake drums.So now I am wondering what the right choice for tires is as they are quite an investment. What does everyone use for a brand and size ? I am looking at putting the Firestone 650x20 (34.6" tall) on the rear and the Denmans 650x20 (32.6" tall) on the front. Any and all opinions would be appreciated.
Thanks, David
are you using the oem wheel or did you just use the oem centers on new outer rim
Using original wheels.
I put the firestone 650-20's on my 41 1.5 ton. I love the way they look, and they fit the fender opening perfectly, much better than the 600-20's that were on there.
Thanks for that. I guess you didn't have any clearance/turning problems with putting them on the front. I was thinking I might have to put the next size smaller on the front. I'd like to put them all around.
Hey David, I see you are located in Mass.
Im in Essex.
My truck is a 2&1/2 ton, it came from the factory with 8.25/20 tires, which were optional. 7.50/20 were standard. When the time comes, Im hoping to use the same size with my original wheels, i want to keep the truck original.
Hey Jeff,
Essex is a nice place to be. Great ship building museum and boat hardware junk shops. The thing that I am finding is that the same tire desigbation, say 6.50, may differ 2" in diameter between brands.
I would like to run as tall a tire as I can get away with for road speed but don't want the truck to look silly. So I'm guessing now with your input that 8.25 would work. The ones available today are 39 1/2" tall ! What is the height of yours ?
Hold on now... don't go buy those 8.25-20 tires just yet.... Jeff hasn't said what model truck he has, and I bet it's not the same.
Also, before buying different tires check that your rim width is compatable with them.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks Grigg,
I was hoping that you would weigh in on this. Have been following all your threads on the wheel "quest". I think that I will go ahead and get 4 of the Firestone 6.50x20 as they are the only truck tread that I can find available. All the others are a highway tread. I'll check the width before I get them.
Thanks, David
If you know anyone in the Ma. area that's looking , I have (7) 19.5 10 bolt rims and (5) good tires that need a home....
