6 members (Samantha, Hotrod Lincoln, mick53, 55shaker, 2-Ton, 1 invisible), 75 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#722487 02/19/2011 8:18 PM
I just rebuilt my 6 volt starter with new brushes,new contact switch ,turned the commutator and did some repair on the fork.
Most of the time it works but sometimes it "just zings" without engaging.
Any suggestions?
Jeff
coolchevy #722501 02/19/2011 9:45 PM
Riding in the Passing Lane
You didnt say anything about the starter drive. You probably need a new one.
1972 Chevy c10 Cheyenne Super
coolchevy #722505 02/19/2011 9:52 PM
3B Offline
Hy coolchevy, did you replace the starter drive? It sounds like it is not working all the time. The other thing that can happen is, the drive does not mesh with the flywheel teeth, but the action of your foot on the starter pedal closes the switch contacts on the motor making it spin. You should check your flywheel teeth for burrs that may be stopping the engagement of the starter drive with the flywheel, hope that helps.
3B #722581 02/20/2011 2:14 AM
Ah Ha ! I didn't replace the starter drive. And it looked a little worn.I will remove the starter and see if I can find a new starter drive locally.
Thanks!
coolchevy #724783 02/26/2011 11:20 PM
Well I replaced the starter drive and everything seems fine. So far so good.
It is too cold here to keep on testing it.
I'll keep you posted
Thanks !
