4 members (BC59, KEVINSKI, dt235sd, Wooley), 135 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
Junior Member
Junior Member
Was wondering if anyone might know if a powerglide bolted onto my 250 would drop into my 66 stepside without disassembling the radiator support, grill, etc. I am thinking it will not.
Thanks for any answers.
With a load-leveler, it should. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
250 is long, powerglide is short. I'm with Brian here, using a load leveler on the engine hoist should give you enough room. If not, put the truck on blocks to do it with the load leveler. Make sure your fluids are drained prior to attempting. Don
Z
Z Offline
i hope the powerglides empty.
Freds
Might just make it,Been a long time But.........
Remember there is just so much room between the firewall/tranny hump AND the fixed position crossmember that was the Original rear mount location for the standard shift trans.
Seem to remember you could sneek a 3speed and engine in there but a 4speed hung to low in the "belly" to leave it on for removal or installation as a pair.
The pan on a powerglide might make it over that c member but I,m leaning on NO,sorry to say.
Its gotta go in AFTER the engine is in,OR before,and stab the motor on it.
Good Luck and Regards
Quote
Originally posted by Freds:
Was wondering if anyone might know if a powerglide bolted onto my 250 would drop into my 66 stepside without disassembling the radiator support, grill, etc...
At a minimum, I'd remove the radiator. Get's expensive to repair a punctured hole :blat: .
