8 members (Phak1, ShopRag, Mr Bailey, Woodcmiami, Otto Skorzeny, Biermann, 78buckshot, DadsFirstPickup),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,147 Posts1,056,801 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72237 01/26/2007 12:09 AM | Joined: Nov 2006 Posts: 25 Junior Member | | Junior Member Joined: Nov 2006 Posts: 25 | Was wondering if anyone might know if a powerglide bolted onto my 250 would drop into my 66 stepside without disassembling the radiator support, grill, etc. I am thinking it will not. Thanks for any answers. | | |
#72238 01/26/2007 12:30 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | With a load-leveler, it should. Brian | | |
#72239 01/26/2007 1:47 AM | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | 250 is long, powerglide is short. I'm with Brian here, using a load leveler on the engine hoist should give you enough room. If not, put the truck on blocks to do it with the load leveler. Make sure your fluids are drained prior to attempting. Don | | |
#72240 01/26/2007 2:50 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i hope the powerglides empty. | | |
#72241 01/27/2007 7:25 AM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Freds Might just make it,Been a long time But......... Remember there is just so much room between the firewall/tranny hump AND the fixed position crossmember that was the Original rear mount location for the standard shift trans. Seem to remember you could sneek a 3speed and engine in there but a 4speed hung to low in the "belly" to leave it on for removal or installation as a pair. The pan on a powerglide might make it over that c member but I,m leaning on NO,sorry to say. Its gotta go in AFTER the engine is in,OR before,and stab the motor on it. Good Luck and Regards | | |
#72242 01/28/2007 4:26 PM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Originally posted by Freds: Was wondering if anyone might know if a powerglide bolted onto my 250 would drop into my 66 stepside without disassembling the radiator support, grill, etc... At a minimum, I'd remove the radiator. Get's expensive to repair a punctured hole :blat: . | | |
