| | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | On the 216 engine that is in my 46 there is a fair bit of wear on the starter side of the ring gear,I would say 20% of the tooth has been worn back. I did take a photo but it is too blurry to see. After looking at the one on the 235 I have this wear seems excessive.Any suggestions as to a cause or could it be normal . Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would have a look at your starter to see if the drive is worn. It probably has been grinding your ring gear. I don't think it is normal to have that much missing. | | |
